[gdal-dev] OGRCoordinateTransformation & MultiThread
    LOPPIN Vincent
    vincent.loppin at cs-soprasteria.com
    Wed Mar  5 01:12:37 PST 2025
Hi there,
In our application, we integrate GDAL (3.8.4 with proj 9.4.0) in order to deals with geographic projections and data loading.
To improve loading & processing time we use multithreading.
Until now everything was right, but we start dealing with dataset expressed on EPSG:28992 (Amersfoort / RD New -- Netherlands - Holland - Dutch).
Then our application starts to crash. After some investigations, it appears that PROJ is modifying the pipeline used to perform transformation.
(Into pipeline, some pop operation)
We use OGRCoordinateTransformation into a wrapper, each Transformation object is unique throught the whole application (I.E. one object to convert EPSG:4326 to EPSG:28992).
For now this implementation works wells (At least for UTM / Lambert / WorldMercator, maybe anothers) but for this particular one don't.
Did we miss something ? Should we have a threadlocal based implementation on OGRCoordinateTransformation object ?
Thanks !
C2 - Usage restreint
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250305/e80ddffa/attachment-0001.htm>
