[gdal-dev] Can we build CSharp Bindings in GDAL v3.9.3 or later with DOT NET FRAMEWORK 4.8?
Parveen Sharma
sharma1981 at outlook.com
Thu Mar 6 03:27:25 PST 2025
Hello tamas
I am trying to build with these options
<arg value="-DBUILD_CSHARP_BINDINGS=ON"/><!-- C# Bindings-->
<arg value="-DCSHARP_LIBRARY_VERSION=netstandard2.0"/>
<arg value="-DCSHARP_APPLICATION_VERSION=netstandard2.0"/>
However, I am getting errors wrt to finding the executables like OGRInfo.exe etc among others
[INFO] [exec] -- Installing: C:/workarea/Source/gdal/build_Debug/install/share/csharp/OgrInfo/OgrInfo.deps.json
[INFO] [exec] CMake Error at swig/csharp/cmake_install.cmake:152 (file):
[INFO] [exec] file INSTALL cannot find
[INFO] [exec] "C:/workarea/Source/gdal/build_Debug/swig/csharp/OgrInfo/OgrInfo.exe":
My question : If I set CMAKE OPTIONS as shown to "netstandard2.0" then do i expect to see the EXEs getting generated as I understand that .NET STANDARD is just specification and not any runtime. Will these make any difference?
Best regards,
Sent: Thursday, March 6, 2025 5:12 PM
To: Parveen Sharma <sharma1981 at outlook.com>
Cc: Michał Kowalczuk via gdal-dev <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Can we build CSharp Bindings in GDAL v3.9.3 or later with DOT NET FRAMEWORK 4.8?
You can let cmake to build the csharp libs for netstandard2.0 ("-DCSHARP_LIBRARY_VERSION=netstandard2.0") which makes it compatible with both the netframework and netcore versions.
Best regards,
Tamas
Parveen Sharma via gdal-dev <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>> ezt írta (időpont: 2025. febr. 19., Sze, 9:59):
Hello
I am trying to build GDAL CSharp bindings from v3.9.3 branch<https://github.com/OSGeo/gdal/tree/v3.9.3/swig/csharp>.
The documentation for v3.9.3<https://gdal.org/en/stable/api/csharp/csharp_compile_cmake.html#net-build-toolchain> states that it needs .NET 5.0 OR Mono
[cid:ii_1956ab8f04dcb971f161]
Question : Is it possible to build GDAL source v3.9.3 using DOT NET Framework 4.8 or less? I am using below flags BUT it seems the build process is attempting to look for only .NET SDK and not the DOT NET FRAMEWORK
<arg value="-DCSHARP_LIBRARY_VERSION=4.8"/>
<arg value="-DCSHARP_APPLICATION_VERSION=4.8"/>
Does GDAL still support building CSharp Bindings with .net framework?
Please let me know.
Best regards,
Parveen
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250306/0d6d63d4/attachment-0001.htm>
Type: image/png
Desc: image.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250306/0d6d63d4/attachment-0001.png>
