[gdal-dev] Zarr BLOCKSIZE in gdalmdimtranslate with variables of varying dimension
    Simon Lyngby Kokkendorff
    silyko at gmail.com
    Wed Mar 12 02:08:57 PDT 2025
Thanks Even,
  That does the trick :)
Cheers,
Simon
On Wed, Mar 12, 2025 at 9:54 AM Even Rouault <even.rouault at spatialys.com> wrote:
> Simon,
> see the ARRAY:IF(DIM=2):BLOCKSIZE=256,256 example of
> GDALGroup::CopyFrom() mentioned at
> https://gdal.org/en/stable/doxygen/classGDALGroup.html#a28324579902842d7dbd1f93e9698b1ec
> Even
> Le 12/03/2025 à 09:23, Simon Lyngby Kokkendorff via gdal-dev a écrit :
> > Hi list,
> >    gdalmdimtranslate is a very handy tool e.g. to translate netCDF
> > files to Zarr as it can handle huge files that xarray just chokes on.
> >     I have a question regarding handling output blocksizes for the Zarr
> > format for files with variables of varying dimensions though. For
> > example I need to translate a netCDF file with time, z, lat, lon
> > dimensions and variables which are either 4D (time, z, lat, lon), 3D
> > (time, lat, lon) and 2D (lat, lon). I would like to remap chunksizes /
> > blocksizes to better suit my use case. However, it seems that I can
> > only specify blocksizes as e.g. -co ARRAY:BLOCKSIZE 2, 2, 128, 128 -
> > which will throw an error and skip the variables that don't  have 4
> > dimensions. Also, the output doesn't contain the dimension variables
> > in this case. Likewise, for 4D variables if I only specify 3
> > blocksizes.
> >    Have tried this with gdal versions 3.8.4 and 3.4.1 with similar results.
> >     So the question is if there is any way to specify blocksizes e.g.
> > by dimension name? Or if the approach should rather be to just create
> > 3 output Zarr folders - one for each variable dimensionality (2D, 3D
> > and 4D)? I can of course manually "merge" these folders afterwards.
> > Best regards,
> > Simon
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
