[gdal-dev] Problem with GPKG, UPSERT, AND OGR2OGR_USE_ARROW_API
    Even Rouault
    even.rouault at spatialys.com
    Mon Mar 24 13:15:53 PDT 2025
Hi Jukka,
> I am not sure if I just should know to avoid the arrow api, of if this behavior could be a bug.
Indeed the Arrow fast path cannot be used in that case. Fix in
https://github.com/OSGeo/gdal/pull/12018 to avoid the explicit --config
OGR2OGR_USE_ARROW_API NO
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250324/97a78fd6/attachment.htm>
