[gdal-dev] Reading Layers In USGS Geospatial Topo Files:
Even Rouault even.rouault at spatialys.com
Tue Mar 25 14:03:22 PDT 2025
Carl,
I don't have one such PDF at hand, but with one sample of the GDAL
autotest suite:
$ gdalinfo autotest/gdrivers/data/pdf/adobe_style_geospatial.pdf -mdd LAYERS
Metadata (LAYERS):
   LAYER_00_NAME=New_Data_Frame
   LAYER_01_NAME=New_Data_Frame.Graticule
   LAYER_02_NAME=Layers
   LAYER_03_NAME=Layers.Measured_Grid
   LAYER_04_NAME=Layers.Graticule
Programatically, you can get this list of layers with
Dataset.GetMetadata("LAYERS")
Then you can select layers you want to activate with the LAYERS open option:
gdal_translate autotest/gdrivers/data/pdf/adobe_style_geospatial.pdf
out.tif -oo LAYERS=New_Data_Frame.Graticule,Layers.Graticule
or disable select ones with the LAYERS_OFF open option:
out.tif -oo LAYERS_OFF=New_Data_Frame.Graticule,Layers.Graticule
Programatically,
gdal.Translate("out.tif", gdal.OpenEx("in.pdf", open_options =
["LAYERS=New_Data_Frame.Graticule,Layers.Graticule"])
Even
Le 25/03/2025 à 21:40, Carl Carlson via gdal-dev a écrit :
> I have almost no experience with GDAL or python, butI do have  57
> years programming experience.  I need some help with GDAL.  At 79 I
> don’t have the time and energy to get deeply into these topics.  I
> need a quick solution
> I am writing a program to copy selected layers from a 7.5’ USGS
> geospatial PDF Topo File and save them as geoTIFFs.  My efforts with
> gdalinfo,  gdal.Open, and gdal.Translate have led me nowhere
> worthwhile.  I can’t find the layers.  I just don’t know enough about
> this.
> Would some kind person help me out with sample code?
> Thanks
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250325/1a4bf28a/attachment-0001.htm>
