[gdal-dev] zarr urls need quoting
Michael Sumner mdsumner at gmail.com
Wed Mar 26 10:32:23 PDT 2025
Ok, thank you that's totally understandable and I will champion your
choices here
Appreciate the (fast) response very much
Cheers, Mike
On Thu, Mar 27, 2025, 04:28 Even Rouault <even.rouault at spatialys.com> wrote:
> Michael,
> > gdalmdiminfo
> > ZARR:"/vsicurl/
> https://data.source.coop/dynamical/noaa-gefs-analysis/v0.0.1-dev.zarr"
> This is a shell issue. It will strip those quotes, and thus be seen by
> GDAL as your below string without quotes.
> > Does it need to be this way for some special zarr reason?
> The requirement for the path to be surrounded by double-quotes is to
> make it more bullet proof to extract it. Particularly for windows with
> c:\bla . Other drivers such as netCDF have workarounds for those use
> cases, but I wasn't willing to implement them again for the new driver.
> The ZARR: prefix is needed for remote datasets to force either probing
> for a few known files in the pointed path or issue a directory listing
> (when available).
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250327/313363d0/attachment.htm>
