[gdal-dev] Can we external libtiff and internal GeoTiff while building GDAL?
    John Smith
    johnsmith7862025 at outlook.com
    Fri Mar 28 09:11:44 PDT 2025
Hello Even,
Thanks for clarifying.
One more question - Our end-users is trying to use the GDAL shared libs (built with internal GeoTIFF and external libTIFF) in a setup where even they have external GeoTIFF and libTIFF libraries.
Can I do something to avoid the symbol clashes in Client setup while building the GDAL ?
Sent: Friday, March 28, 2025 1:16 PM
To: John Smith <johnsmith7862025 at outlook.com>; gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Can we external libtiff and internal GeoTiff while building GDAL?
John,
yes I believe this should work (although probably not much tested).
The reverse is explicitly forbidden though (from frmts/gtiff/CMakeLists.txt):
if (GDAL_USE_TIFF_INTERNAL AND NOT GDAL_USE_GEOTIFF_INTERNAL)
  message(FATAL_ERROR "When GDAL_USE_TIFF_INTERNAL=ON, GDAL_USE_GEOTIFF_INTERNAL must be also set to ON")
endif ()
Even
Le 28/03/2025 à 14:04, John Smith via gdal-dev a écrit :
Hi
Is this allowed if I use GDAL Internal Geotiff and external libtiff library while building GDAL? What all things I need to take care.
Will there be any symbol clashes etc which I need to handle as well?
<arg value="-DGDAL_USE_GEOTIFF_INTERNAL=ON"/>
<arg value="-DGDAL_USE_TIFF_INTERNAL=OFF"/> //Specify external libtiff include and libs My end goal is to have below Options enabled when I run gdalinfo.exe --format gtiff
<CreationOptionList>
      <Option name="COMPRESS" type="string-select">
              <Value>ZSTD</Value>
              <Value>WEBP</Value>
              <Value>LERC</Value>
              <Value>LERC_DEFLATE</Value>
              <Value>LERC_ZSTD</Value>
        </Option>
   // Extra tags
</CreationOptionList>
BR
John
And ho
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250328/47dc61ca/attachment-0001.htm>
