[gdal-dev] [External] : Re: Build failed with "cannot deduce template arguments" error
Fengting Chen fengting.chen at oracle.com
Thu May 1 05:11:02 PDT 2025
Verified that your change worked for my compiler. Thank you!
Date: Wednesday, April 30, 2025 at 6:17 AM
To: Fengting Chen <fengting.chen at oracle.com>, gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: Re: [External] : Re: [gdal-dev] Build failed with "cannot deduce template arguments" error
GCC 8 release notes indicate that C++17 support is still be a bit experimental for the standard library. Anyway, can you try https://github.com/OSGeo/gdal/pull/12231<https://urldefense.com/v3/__https:/github.com/OSGeo/gdal/pull/12231__;!!ACWV5N9M2RV99hQ!LLypbO_HDg16BnOo4IDARi1zrLUzkmyWhmjNTbwBoT0ieGdQEl9YHkmMpYB1ld6UKWExDemX6KdmuKiu28xp8Ye6fs7T$> ? I don't have access to your compiler so I couldn't check with it, but I'd assume it should make template deduction easier for the compiler.
Le 30/04/2025 à 05:10, Fengting Chen a écrit :
I am using “c++ (GCC) 8.5.0 20210514 (Red Hat 8.5.0-18.0.6)” which is supposed to support C++17.
From: Even Rouault <even.rouault at spatialys.com><mailto:even.rouault at spatialys.com>
Date: Tuesday, April 29, 2025 at 6:10 PM
To: Fengting Chen <fengting.chen at oracle.com><mailto:fengting.chen at oracle.com>, gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org> <gdal-dev at lists.osgeo.org><mailto:gdal-dev at lists.osgeo.org>
Subject: [External] : Re: [gdal-dev] Build failed with "cannot deduce template arguments" error
Which compiler and compiler version do you use ? It is likely it is too old and doesn't fully support C++17
Le 29/04/2025 à 23:18, Fengting Chen via gdal-dev a écrit :
Hi, I am trying to build GDAL from the master branch, but got the following error:
[ 46%] Building CXX object alg/CMakeFiles/alg.dir/gdal_interpolateatpoint.cpp.o
In file included from /scratch/gdal/gdal/alg/gdal_interpolateatpoint.cpp:20:
/scratch/gdal/gdal/gcore/gdal_vectorx.h: In member function ?~@~Xgdal::         VectorX<T, N>::self_type gdal::VectorX<T, N>::operator+(T) const?~@~Y:
/scratch/gdal/gdal/gcore/gdal_vectorx.h:173:44: error: cannot deduce template   arguments for ?~@~Xplus?~@~Y from ()
          return operatorImpl(arg, std::plus());
My configuration is:
--   Target system:             Linux
--   Installation directory:    /usr/local
--   C++ Compiler type:         GNU
--   C compile command line:     /bin/cc
--   C++ compile command line:   /bin/c++
--   CMAKE_C_FLAGS:               -fvisibility=hidden
--   CMAKE_CXX_FLAGS:               -fvisibility=hidden
--   CMAKE_CXX17_STANDARD_COMPILE_OPTION:              -std=c++17
--   CMAKE_CXX17_EXTENSION_COMPILE_OPTION:              -std=gnu++17
--   CMAKE_EXE_LINKER_FLAGS:
--   CMAKE_MODULE_LINKER_FLAGS:               -Wl,--no-undefined
--   CMAKE_SHARED_LINKER_FLAGS:               -Wl,--no-undefined
--   CMAKE_STATIC_LINKER_FLAGS:
Any idea on how to fix the error?
Thanks!
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev<https://urldefense.com/v3/__https:/lists.osgeo.org/mailman/listinfo/gdal-dev__;!!ACWV5N9M2RV99hQ!OOJ0fjd1DRqARN5Zwu2h2bUnGxx24Gm7BRrjicc_T6TOWw47z1fKS1DmrwT_3UWuTnrn2lyb2-GqSG_ErtSHw1UapGVT$>
http://www.spatialys.com<https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!OOJ0fjd1DRqARN5Zwu2h2bUnGxx24Gm7BRrjicc_T6TOWw47z1fKS1DmrwT_3UWuTnrn2lyb2-GqSG_ErtSHw2hmL07K$>
http://www.spatialys.com<https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!LLypbO_HDg16BnOo4IDARi1zrLUzkmyWhmjNTbwBoT0ieGdQEl9YHkmMpYB1ld6UKWExDemX6KdmuKiu28xp8WvOW-ur$>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250501/4cce0550/attachment-0001.htm>
