[gdal-dev] GDAL 3.11.0 release candidate available
Sebastiaan Couwenberg
sebastic at xs4all.nl
Mon May 5 22:02:35 PDT 2025
On 5/5/25 9:54 PM, Even Rouault via gdal-dev wrote:
> can you give a try at https://github.com/OSGeo/gdal/pull/12275 ?
Thanks for the quick fix, that resolves the failure on armel & powerpc:
https://buildd.debian.org/status/package.php?p=gdal&suite=experimental
m68k had the same failure, but that build needs several more hours at time of writing.
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
