[gdal-dev] Compoundcurve to DXF
    Rahkonen Jukka
    jukka.rahkonen at maanmittauslaitos.fi
    Wed May  7 04:55:59 PDT 2025
By reading https://gdal.org/en/stable/drivers/vector/dxf.html this feels clear and expected:
"CIRCLE, ELLIPSE, ARC, SPLINE,HELIX: Translated as a LINESTRING, tessellating the curve into line segments"
and
"The OGR_ARC_STEPSIZE and OGR_ARC_MAX_GAP configurations options control the approximation of arcs, ellipses, circles and rounded polylines as linestrings"
I fear that all you have overlooked was the documentation.
-Jukka Rahkonen-
________________________________________
Lähettäjä: gdal-dev käyttäjän Jan Heckman via gdal-dev puolesta
Lähetetty: Keskiviikko 7. toukokuuta 2025 14.47
Vastaanottaja: gdal
Aihe: [gdal-dev] Compoundcurve to DXF
Hi list,I am trying to convert a geopackage layer with compoundcurve geometry to autocad, hoping to get ARCS or bulging (LW)POLYLINE, without tesselation.I can do this in QGis by exporting the project to DXF, but not by saving the layer as DXF.Moreover, the produced XY geometries get garbled with nan's.Direct attempt with ogr2ogr had the same result:ogr2ogr -f DXF rott.dxf GPKG:rotterdam_land24_2.gpkg -nlt compoundcurve -sql "SELECT layer AS Layer, geom FROM land_24_2"-nlt compoundcurve was accepted, but apparently not applied.Is this expected? Have I overlooked something? If not, is there a plan to add this functionality?The data (104 kb) can be downloaded from this dropbox link.Best regards,Jan
