[gdal-dev] Compoundcurve to DXF
    Even Rouault
    even.rouault at spatialys.com
    Wed May  7 07:53:21 PDT 2025
Le 07/05/2025 à 15:11, Jan Heckman via gdal-dev a écrit :
> Hi Jukka,
> You are right, excuses. My question was a bit rhetorical, though.
> Will you please answer the 2nd question too?
> I get the impression that there is no intention yet to convert curves
> to DXF arcs.
> I hope you change your mind, you can look to QGis to see some details,
> I believe.
This is not a question of "mind". Just someone has to make the effort to
code support for writing curves
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250507/b278683e/attachment.htm>
