[gdal-dev] [External] : Re: GDAL 3.10.3 build questions regarding to CURL and ARROW
Fengting Chen
fengting.chen at oracle.com
Thu May 8 14:40:46 PDT 2025
Thanks for the reply. The CURL is temporarily resolved. But the build on ARROW still has problem.
Setting Arrow_DIR didn’t work as GDAL cmake cannot find arrow anymore. Setting Arrow_ROOT allows GDAL cmake to find arrow, just the compilation failed. The same Arrow_ROOT setting works for the build of GDAL 3.8.4, but not 3.10.3. Not sure if there is anything changed between the two versions that caused the compilation failure.
Date: Thursday, May 8, 2025 at 1:39 PM
To: Fengting Chen <fengting.chen at oracle.com>, gdal-dev <gdal-dev at lists.osgeo.org>
Subject: [External] : Re: [gdal-dev] GDAL 3.10.3 build questions regarding to CURL and ARROW
Le 08/05/2025 à 19:15, Fengting Chen via gdal-dev a écrit :
I have a couple questions regarding to building GDAL 3.10.3:
1. Error about CURL:
Could NOT find CURL: Found unsuitable version "7.61.1", but required is at least "7.68" (found /usr/lib64/libcurl.so, )
Any reason that curl 7.68 and higher is required?
Cf https://gdal.org/en/stable/development/rfc/rfc98_build_requirements_gdal_3_9.html<https://urldefense.com/v3/__https:/gdal.org/en/stable/development/rfc/rfc98_build_requirements_gdal_3_9.html__;!!ACWV5N9M2RV99hQ!Ogh2I513LdvztVcK6Y1ytzMbeH2ZyHRKHAUQajL7253eDXqVXLNpeOLC5DIohBHzHXLGfiqtJjjAheNqC2gUqbzNKzJ9$> . Maybe you can modify the minimum version to 7.61.1 but that isn't tested in CI.
1. In the build of GDAL 3.10.3, GDAL_USE_ARROW, GDAL_USE_ARROWDATASET and GDAL_USE_PARQUET are on. The Arrow_ROOT, Parquet_ROOT and ArrowDataset_ROOT are set to the installation of arrow. But the build gave error:
I doubt those variables are honored. Try setting CMAKE_PREFIX_PATH to the installation prefix of libarrow, or set Arrow_DIR, Parquet_DIR, ArrowDataset_DIR and ArrowAcero_DIR similar to below:
ArrowAcero_DIR=/home/even/install-arrow-20.0.0/lib/cmake/ArrowAcero
ArrowDataset_DIR=/home/even/install-arrow-20.0.0/lib/cmake/ArrowDataset
Arrow_DIR=/home/even/install-arrow-20.0.0/lib/cmake/Arrow
Parquet_DIR=/home/even/install-arrow-20.0.0/lib/cmake/Parquet
http://www.spatialys.com<https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!Ogh2I513LdvztVcK6Y1ytzMbeH2ZyHRKHAUQajL7253eDXqVXLNpeOLC5DIohBHzHXLGfiqtJjjAheNqC2gUqYXqWzDM$>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250508/70dd236b/attachment-0001.htm>
