[gdal-dev] replacing a dataset in C++
Even Rouault even.rouault at spatialys.com
Sat May 10 15:29:40 PDT 2025
Le 11/05/2025 à 00:20, Michael Sumner via gdal-dev a écrit :
> Hello, I have a question about safely re-casting a dataset to another,
> I want to use Multidim to re-orient an MDArray as a classic 2D raster.
> I was a bit surprised that this works (I just overwrite poSrcDS with
> the classic form):
> I'm passing in 'osFilename', 'osArrayName' and two dimension indexes
> 'index_x' and 'index_y', the first "Open()" line is a literal copy
> from vrtdataset.cpp:
> // I've removed all the nullptr checks from this code
> auto poSrcDS = std::unique_ptr<GDALDataset, GDALDatasetUniquePtrReleaser>(
>          GDALDataset::Open(osFilename, GDAL_OF_RASTER |
> GDAL_OF_VERBOSE_ERROR,
>                           aosAllowedDrivers.List(), aosOpenOptions.List(),
>                           nullptr));
> // now open in mdim mode, and get the specified MDArray in Classic
> form with index_x,index_y
> auto poMDimDS =
> std::unique_ptr<GDALDataset>(GDALDataset::Open(osFilename,
> GDAL_OF_MULTIDIM_RASTER));
> auto poMdimGroup = poMDimDS->GetRootGroup();
> auto poArrayDS = poMdimGroup->OpenMDArrayFromFullname(osFilename);
> auto poClassicDS = poArrayDS->AsClassicDataset(index_x, index_y);
> // FIXME how to safely swap poSrcDS with poClassicDS
> GDALDatasetUniquePtrReleaser>(poClassicDS);
> My question is about the last line where poClassic "replaces" poSrcDS:
> what am I responsible for to make that safe?
That's perfectly fine. In the mdim API, objects returned by
GetRootGroup(), OpenMDArray(), AsClassicDataset(), etc. , keep the
necessary parent objects alive through shared_ptr mechanism. Furthermore
in your example, there is no relationship between poSrcDS et
poClassicDS, so even if that wasn't the case, your final assignment
would be still safe.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250511/b4729a37/attachment.htm>
