[gdal-dev] GDAL 3.11 broke part of the Julia wrapper
Even Rouault even.rouault at spatialys.com
Sun May 11 16:15:22 PDT 2025
Le 12/05/2025 à 01:04, Joaquim Manuel Freire Luís via gdal-dev a écrit :
> Hi,
> I’m afraid this one is not going to be easy, and I don’t know how much
> help I can provide to find the issue. The think is that
> https://github.com/OSGeo/gdal/pull/12124 (which is a very big PR)
> broke my Julia wrapper.
> For example, this used to write a png image but now it errors with
> julia> gdalwrite("lixo.png", mat2img(UInt8.([1 2 3; 4 5 6; 7 8 9])))
> ERROR 1: Cannot guess driver for lixo.png
> But maybe more concrete is this failure where it tries to extract info
> from a gdal dataset (a pointer )
> Gdal.GDALGetRasterYSize(dataset.ptr)
> 49
> Gdal.GDALGetRasterCount(dataset.ptr)
> 1
> Gdal.GDALDatasetGetLayerCount(dataset.ptr)
> 0
> Here, first two are correct be the third is now wrong.
Why is GDALDatasetGetLayerCount() == 0 wrong on a raster dataset ? It
looks like the expected result
If I'm looking at the correct source code
https://github.com/GenericMappingTools/GMT.jl/blob/94649db2b48d3223c8b8628b6fac4d3df60b8938/src/gdal_utils.jl#L859
, then this line is fragile. Rather than testing if OGRGetDriverByName()
returns a non null pointer to guess if that dataset is raster or vector,
you could indeed test GDALGetRasterCount() != 0 to infer this is a
raster dataset.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250512/de2f0453/attachment-0001.htm>
