[gdal-dev] RFCs
Even Rouault
even.rouault at spatialys.com
Wed May 14 10:54:06 PDT 2025
Hi Andrew,
Can you be more specific about which RFCs ? Quick grep shows RFC9
superseded per RFC83 and RFC68 superseded per RFC98.
If that can help, we could potentially keep in master a mostly empty
document for superseded RFCs that would contain just a link to the new
RFC and a link to the supersed text pointing at
https://gdal.org/en/release-{last-one-with-the-full-text}/development/rfc/rfc-XXXX.html
Even
Le 14/05/2025 à 19:45, Andrew Bell via gdal-dev a écrit :
> Hi,
> I was wondering if some of the RFCs should be placed somewhere other
> than on the web site because they are obsolete/superseded. I think
> this would make it easier to find relevant current information. Some
> of the RFCs are marked as superseded, but from the standpoint of a web
> search, the more there is to read through, the less likely that I'll
> find the correct information that I'm looking for.
> Thoughts?
> Andrew Bell
> andrew.bell.ia at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250514/95eb778a/attachment.htm>
