[gdal-dev] raster reproject fails without error message with GCP_HOMOGRAPHY option
Andrew C Aitchison
andrew at aitchison.me.uk
Wed May 21 06:56:46 PDT 2025
On Wed, 21 May 2025, Schumacher, Mia via gdal-dev wrote:
>> I am trying to use new gdal raster reproject to georeference image chunks
>> using ground control points. I figured that for some of these chunks, due
>> to ship movement, the lower left & lower right image coordinates are
>> switched, which (understandably) leads the algorithm to fail. however,
>> there is no error message, it just doesn't produce output. I use:
> gdal raster reproject -r bilinear --to SRC_METHOD=GCP_HOMOGRAPHY --co
> COMPRESS=DEFLATE -d EPSG:4326 -i 2025-03-17_08-30-44_0_ch0_0_chunk_tmp.tif -o
> 2025-03-17_08-30-44_0_ch0_0_chunk_tmp_WGS84.tif
>> with gcps applied like so:
> gdal_translate -of GTiff \
> -gcp im_x_ul im_y_ul lon_ul, lat_ul \
> -gcp im_x_ur im_y_ur lon_ur, lat_ur \
> -gcp im_x_ll im_y_l lon_ll, lat_ll \
> -gcp im_x_lr im_y_lr lon_lr, lat_lr
> (ul/r, ll/r = upper/lower left/right) --> but sometimes, ll and lr are
> switched
>> I would love to catch the error to adjust those files - Is there something
>> like a verbose mode for gdal raster reproject? Then i could see what is
>> going on?
gdal_translate --debug on
might give you more information.
(I am also not sure that your have the right numbe of commas
in the line above.)
Andrew C. Aitchison Kendal, UK
