[gdal-dev] Problem generating a tif, vrt and displaying it via mapserver
Stephen Woodbridge
stephenwoodbridge37 at gmail.com
Tue May 27 10:58:16 PDT 2025
Hi Seth,
Thank you for looking at this.
There are no errors in the apache error.logs.
Here is a tile request to mapserver:
https://map52.saltwatercentral.com/cgi-bin/mapserv?map=%2Fmaps%2Fwms%2Fhycom_2d_1.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image%2Fpng&TRANSPARENT=true&LAYERS=mlt&format=image%2Fpng&version=1.3.0&WIDTH=256&HEIGHT=256&CRS=EPSG%3A3857&STYLES=&BBOX=-8766409.899970295%2C5322463.153553393%2C-8453323.832114212%2C5635549.2214094745
Here is a mapserver query request to that layer:
https://map51.saltwatercentral.com/cgi-bin/mapserv?map=/maps/wms/hycom_2d_1.map&mode=query&type=mlt&layers=query&mapxy=-67+37
I,ve tried a lot of different locations with the same result.
The OpenLayers app has lots of controls to turn on/off layers and ajax
requests to get info from the server based on user interactions and
click events.
-Steve
On 5/27/2025 1:41 PM, Seth G wrote:
> Hi Steve,
> Anything in the MapServer logs? And what is the actual network request
> to MapServer?
> You do have a "visible: false" set in your OpenLayers code - I presume
> this gets changed by a legend at some point.
> Seth
> mastodon: @geographika at mastodon.social
> On Mon, May 26, 2025, at 10:28 PM, Stephen Woodbridge via gdal-dev wrote:
>> Hi all,
>> I'm being pulled out of retirement to fix something I created years
>> ago. I'm probably doing something stupid but I haven't been able to
>> sort it out, so ask for some help.
>> System: Ubuntu-22.04
>> GDAL 3.4.1, released 2021/12/27
>> OpenLayers 5.3.3
>> MapServer version 7.6.4 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
>> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
>> SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV SUPPORTS=FRIBIDI
>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
>> SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=POINT_Z_M
>> SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>> INPUT=SHAPEFILE
>> Right some of this is pretty old, but I suspect that is not the
>> current issue.
>> 1. I extract some data from HYCOM and generate a GTiff
>> 2. Manually generate a VRT to add a color table
>> 3. Have a mapserver mapfile to display it
>> Step 1. seems to work fine, but when I do a mapserver query I get no
>> results
>> Step 2. seems to look good and if a gdal_translate -of PNG -outsize
>> 1% 1% source target the image displays
>> Step 3. just gives me empty transparent tiles in OpenLayers
>> Here is the gdalinfo results for the GTif:
>> $ gdalinfo -stats -hist HYCOM_tomorrow_mld.tif
>> Driver: GTiff/GeoTIFF
>> Files: HYCOM_tomorrow_mld.tif
>> Size is 4500, 4251
>> Coordinate System is:
>> GEOGCRS["WGS 84",
>> DATUM["World Geodetic System 1984",
>> ELLIPSOID["WGS 84",6378137,298.257223563,
>> LENGTHUNIT["metre",1]]],
>> PRIMEM["Greenwich",0,
>> ANGLEUNIT["degree",0.0174532925199433]],
>> CS[ellipsoidal,2],
>> AXIS["geodetic latitude (Lat)",north,
>> ORDER[1],
>> AXIS["geodetic longitude (Lon)",east,
>> ORDER[2],
>> ID["EPSG",4326]]
>> Data axis to CRS axis mapping: 2,1
>> Origin = (-180.000000000000000,90.000000000000000)
>> Pixel Size = (0.080000000000000,-0.040000000000000)
>> Metadata:
>> AREA_OR_POINT=Area
>> Image Structure Metadata:
>> INTERLEAVE=BAND
>> Corner Coordinates:
>> Upper Left (-180.0000000, 90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"N)
>> Lower Left (-180.0000000, -80.0400000) (180d 0' 0.00"W, 80d 2'24.00"S)
>> Upper Right ( 180.0000000, 90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"N)
>> Lower Right ( 180.0000000, -80.0400000) (180d 0' 0.00"E, 80d 2'24.00"S)
>> Center ( 0.0000000, 4.9800000) ( 0d 0' 0.01"E, 4d58'48.00"N)
>> Band 1 Block=4500x1 Type=Float32, ColorInterp=Gray
>> Minimum=2.000, Maximum=5000.000, Mean=96.114, StdDev=346.786
>> 0...10...20...30...40...50...60...70...80...90...100 - done.
>> 256 buckets from -7.8 to 5009.8:
>> 1489490 2306537 1907189 2028756 996825 306674 493493 0 196427 0
>> 94515 0 0 33174 0 22423 0 0 11571 0 5892 0 0 0 0 8326 0 0 0 0 0 8045
>> 0 0 0 0 7615 0 0 0 0 6418 0 0 0 0 5695 0 0 0 0 4944 0 0 0 0 0 0 0 0 0
>> 0 0 0 13673 0 0 0 0 0 0 0 0 0 0 0 17543 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
>> 0 0 0 0 0 0 0 0 0 0 31132 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
>> 0 0 30109 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 40660 0 0
>> 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
>> 0 0 0 0 0 0 0 0 0 0 0 0 0 28594 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
>> 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1702
>> NoData Value=-30000
>> Overviews: 2250x2126, 1125x1063, 563x532, 282x266, 141x133, 71x67
>> Metadata:
>> STATISTICS_MAXIMUM=5000
>> STATISTICS_MEAN=96.114400289494
>> STATISTICS_MINIMUM=2
>> STATISTICS_STDDEV=346.78571541402
>> STATISTICS_VALID_PERCENT=52.78
>> My assumption based on this is that I want to scale the 5000 to 250
>> in the VRT which will be Type=Byte, So here is the VRT file.
>> $ cat HYCOM_tomorrow_mld.vrt <VRTDataset
>> rasterXSize="72000" rasterYSize="68016">
>> <SRS>GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
>> 84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]]</SRS>
>> <GeoTransform> -180.0 ,0.005 , 0 , 90.0 , 0 , -0.0025 </GeoTransform>
>> <Metadata>
>> </Metadata>
>> <VRTRasterBand dataType="Byte" band="1">
>> <ColorInterp>Palette</ColorInterp>
>> <ColorTable>
>> <Entry c1="0" c2="0" c3="0" c4="255"/>
>> [Snip lots of entries]
>> <Entry c1="255" c2="255" c3="255" c4="255"/>
>> </ColorTable>
>> <ComplexSource resampling="bilinear">
>> <SourceFilename
>> relativeToVRT="1">HYCOM_tomorrow_mld.tif</SourceFilename>
>> <SourceBand>1</SourceBand>
>> <SrcRect xOff="0" yOff="0" xSize="4500" ySize="4251"/>
>> <DstRect xOff="0" yOff="0" xSize="72000" ySize="68016"/>
>> <ScaleRatio>1</ScaleRatio>
>> <NODATA>0</NODATA>
>> </ComplexSource>
>> </VRTRasterBand>
>> </VRTDataset>
>> So to scale the data I set ScaleRatio to 0.05, but the PNG image
>> doesn't look right and setting it to "1" does look correct. I'm also
>> confused as to what to set NODATA value to. One source said/implied
>> that the NoData of the source file would get set to NODATA value in
>> the VRT, but seem to be countered by the GDAL online docs.
>> Here is the gdalinfo for the VRT:
>> $ gdalinfo -stats -hist HYCOM_tomorrow_mld.vrt
>> Driver: VRT/Virtual Raster
>> Files: HYCOM_tomorrow_mld.vrt
>> Size is 72000, 68016
>> GEOGCRS["WGS 84",
>> CS[ellipsoidal,2],
>> ORDER[1],
>> ORDER[2],
>> ID["EPSG",4326]]
>> Pixel Size = (0.005000000000000,-0.002500000000000)
>> Corner Coordinates:
>> Band 1 Block=128x128 Type=Byte, ColorInterp=Palette
>> 256 buckets from -0.5 to 255.5:
>> 0 0 534720 0 330663 0 149196 0 241797 0 233114 0 285113 0 0 385666
>> 0 0 0 0 574491 0 0 0 0 517919 0 0 0 0 543348 0 0 0 0 455442 0 0 0 0
>> 487763 0 0 0 0 530058 0 0 0 0 433926 0 0 0 0 0 0 0 0 0 1117668 0 0 0
>> 0 0 0 0 0 0 911088 0 0 0 0 0 0 0 0 0 602087 0 0 0 0 0 0 0 0 0 394738
>> 0 0 0 0 0 0 0 0 0 306674 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
>> 0 0 493493 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 196427 0 0
>> 0 0 0 0 0 0 0 0 0 0 0 0 94515 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
>> 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 33174 0 0 0
>> 0 244342
>> Overviews: 36000x34016, 18000x17008, 9008x8512, 4512x4256,
>> 2256x2128, 1136x1072
>> Metadata:
>> Color Table (RGB with 256 entries)
>> 0: 0,0,0,255
>> [snip additional entries]
>> And finally the mapfile that is getting used via OpenLayers:
>> MAP
>> NAME "HYCOM_2d_2"
>> STATUS ON
>> SIZE 950 600
>> EXTENT -180 -90 180 90
>> UNITS DD
>> IMAGECOLOR "#000000"
>> IMAGETYPE agg_qn
>> MAXSIZE 4096
>> CONFIG ON_MISSING_DATA "IGNORE"
>> # CONFIG MS_ERRORFILE "stderr"
>> # DEBUG 10
>> OUTPUTFORMAT
>> NAME "agg_qn"
>> DRIVER "AGG/PNG"
>> EXTENSION "png"
>> MIMETYPE "image/png"
>> IMAGEMODE RGBA
>> FORMATOPTION "INTERLACE=false"
>> FORMATOPTION "QUANTIZE_NEW=ON"
>> FORMATOPTION "QUANTIZE_FORCE=ON"
>> FORMATOPTION "QUANTIZE_DITHER=OFF"
>> FORMATOPTION "QUANTIZE_COLORS=256"
>> TRANSPARENT ON
>> FORMATOPTION "TRANSPARENT=ON"
>> END
>> OUTPUTFORMAT
>> NAME aggpng24
>> DRIVER AGG/PNG
>> IMAGEMODE RGB
>> EXTENSION "png"
>> END
>> OUTPUTFORMAT
>> NAME jpeg
>> DRIVER AGG/JPEG
>> MIMETYPE "image/jpeg"
>> IMAGEMODE RGB
>> EXTENSION "jpg"
>> FORMATOPTION "GAMMA=0.75"
>> FORMATOPTION "QUALITY=75"
>> END
>> WEB
>> METADATA
>> labelcache_map_edge_buffer "-20"
>> "ows_title" "iMaptools - HYCOM data"
>> "ows_onlineresource"
>> "http://map01.saltwatercentral.com/cgi-bin/mapserv?MAP=/maps/wms/hycom_2d_2.map"
>> <http://map01.saltwatercentral.com/cgi-bin/mapserv?MAP=/maps/wms/hycom_2d_2.map>
>> "ows_srs" "EPSG:4326 EPSG:900913 EPSG:3857"
>> "ows_contactperson" "Stephen Woodbridge"
>> "ows_contactorganization" "iMaptools.com"
>> "ows_contactposition" "Owner"
>> "ows_contactelectronicmailaddress" "info at imaptools.com"
>> <mailto:info at imaptools.com>
>> "ows_enable_request" "GetMap"
>> "ows_http_max_age" "3200"
>> END
>> END
>> PROJECTION "init=epsg:4326" END
>> LAYER
>> NAME "ssh"
>> STATUS ON
>> TYPE RASTER
>> DATA "/maps/wms/data/HYCOM/HYCOM_tomorrow_ssh.vrt"
>> PROCESSING "NODATA=-30000"
>> PROCESSING "SCALE=-1.0,1.0"
>> END
>> LAYER
>> NAME "mlt"
>> STATUS ON
>> TYPE RASTER
>> DATA "/maps/wms/data/HYCOM/HYCOM_tomorrow_mlt.vrt"
>> #PROCESSING "NODATA=1.2676506002282294e+30"
>> PROCESSING "SCALE=0,250"
>> END
>> LAYER
>> NAME "query"
>> STATUS ON
>> TYPE raster
>> VALIDATION 'type' '.' END
>> TOLERANCE 0
>> TOLERANCEUNITS pixels
>> DATA "/maps/wms/data/HYCOM/HYCOM_tomorrow_%type%.tif"
>> TEMPLATE "/maps/wms/pixel.value.html"
>> END
>> END
>> I've tried various options of including PROCESSING "NODATA=' and
>> PROCESSING "SCALE=" to no success. And the "ssh" layer which is
>> nearly identical seems to would fine.
>> It get displayed via OpenLayers using a layer definition like:
>> hycom_mlt_2: new TileLayer({
>> title: 'Mixed Layer Depth (0.3degC chg)',
>> clickable: 'hycom_mlt_2',
>> type: 'overlay',
>> visible: false,
>> source: new TileWMS({
>> projection: 'EPSG:3857',
>> urls: getMapUrls('//', map_hosts,
>> '/cgi-bin/mapserv?map=/maps/wms/hycom_2d_2.map'),
>> params: {
>> 'LAYERS': 'mlt',
>> 'format': 'image/png',
>> 'version': '1.3.0'
>> I would appreciate any assistance in figuring out what I'm doing wrong.
>> Thanks,
>> Steve
>> <https://www.avast.com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=emailclient>
>> Virus-free.www.avast.com
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
This email has been checked for viruses by Avast antivirus software.
www.avast.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250527/62c8e371/attachment-0001.htm>
