[gdal-dev] Black artifacts with JPEG compression
Even Rouault
even.rouault at spatialys.com
Tue May 27 12:43:30 PDT 2025
> Am I overlooking something in my process?
No, you're just hitting a fundamental limitation of JPEG compresson
> Do you have any ideas on how I can get rid of the artifacts while
> still keeping disk usage low?
Use lossy WEBP compression that fully supports transparency.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250527/57bf9118/attachment.htm>
