[gdal-dev] Wrong results during translate input.tif file to output.xyz file with gdal_translate.exe
    Rahkonen Jukka
    jukka.rahkonen at maanmittauslaitos.fi
    Wed May 28 10:14:37 PDT 2025
The link does not work for me. All I get is a Not found error "The requested URL was not found on this server."
-Jukka Rahkonen-
________________________________________
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> käyttäjän Marián Hadri via gdal-dev <gdal-dev at lists.osgeo.org> puolesta
Lähetetty: Keskiviikko 28. toukokuuta 2025 18.45
Vastaanottaja: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Aihe: [gdal-dev] Wrong results during translate input.tif file to output.xyz file with gdal_translate.exe
Hallo,I installed gdal 3.10.2 with gdal_translate.exe as well. I tried to translate the file "input.tif" to the file "output.xyz".When I did it with ... gdal_translate.exe -of XYZ "input.tif" "output.xyz", I got the file output.xyz which containsa lot of z-coordinates, like "-3.4028230607370965e+38", which is nonsense, because when I opened this input.tiffile with QGIS, the z-coordinates were in the range "643.2 - 925.2". Could you take a look at this, where is the problem ?Here is the link with file, which is causing the problems ... https://d.rib-software.com/iTWOI_civil/gdaltmp/input.tifThanks in advance, Marian Hadri
