[gdal-dev] GDAL mailing list email delays
    Daniel Baston
    dbaston at gmail.com
    Thu May 29 11:09:22 PDT 2025
I experience the same with GDAL and other OSGeo mailing lists. The
delay in receiving a message can be as much as two days, and messages
often arrive out-of-sequence. Other times things happen more or less
instantaneously.
Folks spent some time investigating the issue with the geos-devel list
but it was not resolved. Anecdotally, it seems to be mostly
experienced by Daniels using Gmail.
Dan
On Thu, May 29, 2025 at 1:29 PM Daniel Evans via gdal-dev
<gdal-dev at lists.osgeo.org> wrote:
> Hi all,
> Over the last couple of months, I've been receiving emails from the gdal-dev list with a significant delay, with emails from threads sometimes arriving out of order.
> For example, in the recent thread on Java bindings, the email headers show the following;
> Tom's initial email was delayed by 48 minutes, arriving at 1715 UTC:
> - Originally sent by the mailing list at 1627 UTC
> - After a few internal hops, received by lists.osgeo.org at 1636 UTC (with a header stating X-Greylist: delayed by 473 seconds)
> - Received my email provider's servers at 1715 UTC
> Even's reply was rather speedier, arriving at 1705 UTC, ten minutes before the email it was replying to:
> - Originally sent by the mailing list at 1705
> - Received by lists.osgeo.org at 1705
> - Received by my email provider at 1705
> Has anyone else been observing similar behaviour? Given that some people are replying before I see earlier emails, it's clearly not the same for all recipients.
> Cheers,
> Daniel
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
