[gdal-dev] Java bindings to gdal/ogr - looking for more developer documentation
    Even Rouault
    even.rouault at spatialys.com
    Fri May 30 14:53:54 PDT 2025
Le 30/05/2025 à 23:39, Tom Moore a écrit :
> Hi Even
> I just wanted to update you and provide a record for posterity with
> the results of me playing around with gdal/java and resource management.
> It appears to me that Dataset objects should not be closed from Java
> client code.  If you do then often there will be an access violation
> (native null pointer) that will crash the JVM. From the dump file the
> following stack trace shows the Java code being executed when the
> exception occurs:
I believe this issue should be fixed in 3.11.0 per
https://github.com/OSGeo/gdal/commit/ec4ca7930b48653bb0fac27b59c6c1bf883c45f2
Actually historically this was the .delete() method that should be
called. The exposition of .Close() is quite recent and was broken (until
the above mentioned fix)
> Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
> j  org.gdal.gdal.gdalJNI.delete_Dataset(J)V+0
> j  org.gdal.gdal.Dataset.delete()V+25
> j  org.gdal.gdal.Dataset.finalize()V+1
> j  java.lang.System$2.invokeFinalize(Ljava/lang/Object;)V+1
> java.base at 21.0.6
> j
> java.lang.ref.Finalizer.runFinalizer(Ljdk/internal/access/JavaLangAccess;)V+115
> java.base at 21.0.6
> j  java.lang.ref.Finalizer$FinalizerThread.run()V+29 java.base at 21.0.6
> So it looks like the swig bindings implement a finalizer to dispose of
> the native object when the reference is no longer reachable (nice!).
> However it looks like there might not be any protection to prevent bad
> things from happening when the Delete method is called more than
> once.  It appears that in this case that when the finalizer calls
> Delete on the Dataset the jvm crashes because the Dataset has already
> been closed manually and the resources have already been released.
> If I am correct in this conclusions then this is not a problem.  If
> correct I suggest that either the docs be updated to indicate do not
> manually call Delete on the Dataset object, or change the Delete
> method code to gracefully handle multiple calls (better choice).
> By the way, something to note for the future is that finalizers have
> been deprecated since Java 9 (2017).  This is described in
> https://openjdk.org/jeps/421. Although deprecated, finalizers are
> still allowed in modern jdk's and probably will be for a while yet. At
> some future time they will be removed.  The suggested replacement for
> finalizers are cleaners, but they are only available in Java 9+.  When
> finalizers are removed there will need to be a new set of bindings
> that use cleaners.  You can probably ignore this problem for a few
> more years, but at some point you will need to provide two sets of
> Java bindings (one required for Java 8 and earlier, and one required
> for some future Java and later).
Thanks for the heads up. Seizing the opportunity to remind interesting
parties in the GDAL Java bindings that they should not be shy and are
welcome to be proactive. On my side, they are very very minimilastically
maintained.
Even
http://www.spatialys.com
