[gdal-dev] Not writing PAM files
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Nov 3 06:12:30 PST 2025
Thank you David.
Unfortunately I don't want to (a.k.a. cannot) change the original files. I
don't want to write any type of file in that directory (like the .aux.xml
files).
(note: I am opening the files in C++ with GDALOpenEx)
On Mon, 3 Nov 2025 at 14:45, David Klaus <dklaus at carlsonsw.com> wrote:
> Hi Javier,
> I'm not sure if this applies to your use case, but I ran into a similar
> issue embedding geolocation information in PDF files. Sidecar files were
> created, but the geolocation data wasn’t embedded directly in the PDF.
> At my company, we use the C++ GDAL API, and I was able to resolve it by
> opening the GDALDataset with the GDALAccess::GA_Update flag.
> As for whether GDAL reads sidecar files when present—I believe it does,
> but I'm not entirely certain, so I’ll defer to others on that point.
> Hope this helps,
> On Mon, Nov 3, 2025 at 4:13 AM Javier Jimenez Shaw via gdal-dev <
> gdal-dev at lists.osgeo.org> wrote:
>> Hi
>> When I read some raster files (in particular thermal JPEG files), a side
>> car file .aux.xml appears next to it.
>> I would like to avoid the creation of this side car file, but I want to
>> use any .aux.xml file if it is already there. Yes, I could imagine there is
>> a performance impact if I read it several times, but I am going to read the
>> file only once.
>> The config option GDAL_PAM_ENABLED seems to be completely disabling PAM
>> functionality:
>> https://gdal.org/en/stable/user/configoptions.html#persistent-auxiliary-metadata-pam-options
>> Reading the documentation, I would imagine that the PAM is completely
>> disabled, not only the creation of the side car file while reading a raster.
>> Is it posible to not create the .aux.xml, but use it if present?
>> Thank you
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> David Klaus
> Carlson Software
> *Disclaimer*
> The information contained in this communication from the sender is
> confidential. It is intended solely for use by the recipient and others
> authorized to receive it. If you are not the recipient, you are hereby
> notified that any disclosure, copying, distribution or taking action in
> relation of the contents of this information is strictly prohibited and may
> be unlawful.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251103/093b47e8/attachment.htm>
