[gdal-dev] Not writing PAM files
Daniel Evans daniel.fred.evans at gmail.com
Mon Nov 3 06:26:28 PST 2025
Hi David,
I'm familiar with the sort of behaviour Javier mentions from using QGIS.
Opening some file formats in read-only mode in QGIS (at least, I assume
that's what QGIS defaults to if I just view a raster!) will cause
"nuisance" .aux.xml sidecar files to be written with band statistics.
Cheers,
Daniel
On Mon, 3 Nov 2025, 14:20 David Klaus via gdal-dev, <
gdal-dev at lists.osgeo.org> wrote:
> Javier,
> That is strange. I could be wrong and maybe someone can weigh in if I am.
> But, I believe that aux files are created when you try to write information
> about or into the file that can't be stored within the file (for one reason
> or another). Are you trying to generate information about the file? Perhaps
> a code snippet would help everyone identify the issue?
> On Mon, Nov 3, 2025 at 9:12 AM Javier Jimenez Shaw <j1 at jimenezshaw.com>
> wrote:
>> Thank you David.
>> Unfortunately I don't want to (a.k.a. cannot) change the original files.
>> I don't want to write any type of file in that directory (like the .aux.xml
>> files).
>> (note: I am opening the files in C++ with GDALOpenEx)
>> On Mon, 3 Nov 2025 at 14:45, David Klaus <dklaus at carlsonsw.com> wrote:
>>> Hi Javier,
>>> I'm not sure if this applies to your use case, but I ran into a similar
>>> issue embedding geolocation information in PDF files. Sidecar files were
>>> created, but the geolocation data wasn’t embedded directly in the PDF.
>>> At my company, we use the C++ GDAL API, and I was able to resolve it by
>>> opening the GDALDataset with the GDALAccess::GA_Update flag.
>>> As for whether GDAL reads sidecar files when present—I believe it does,
>>> but I'm not entirely certain, so I’ll defer to others on that point.
>>> Hope this helps,
>>> On Mon, Nov 3, 2025 at 4:13 AM Javier Jimenez Shaw via gdal-dev <
>>>> Hi
>>>> When I read some raster files (in particular thermal JPEG files), a
>>>> side car file .aux.xml appears next to it.
>>>> I would like to avoid the creation of this side car file, but I want to
>>>> use any .aux.xml file if it is already there. Yes, I could imagine there is
>>>> a performance impact if I read it several times, but I am going to read the
>>>> file only once.
>>>> The config option GDAL_PAM_ENABLED seems to be completely disabling PAM
>>>> functionality:
>>>> https://gdal.org/en/stable/user/configoptions.html#persistent-auxiliary-metadata-pam-options
>>>> Reading the documentation, I would imagine that the PAM is completely
>>>> disabled, not only the creation of the side car file while reading a raster.
>>>> Is it posible to not create the .aux.xml, but use it if present?
>>>> Thank you
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> David Klaus
>>> Carlson Software
>>> *Disclaimer*
>>> The information contained in this communication from the sender is
>>> confidential. It is intended solely for use by the recipient and others
>>> authorized to receive it. If you are not the recipient, you are hereby
>>> notified that any disclosure, copying, distribution or taking action in
>>> relation of the contents of this information is strictly prohibited and may
>>> be unlawful.
> David Klaus
> Carlson Software
> *Disclaimer*
> be unlawful.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251103/9105d185/attachment.htm>
