[gdal-dev] Not writing PAM files
Even Rouault even.rouault at spatialys.com
Mon Nov 3 08:04:50 PST 2025
Hi Javier,
.aux.xml file is no longer generated on opening per
https://github.com/OSGeo/gdal/commit/2ad4ebf4ddcaa74af2d4cea212fb61f0ac382f20
Even
Le 03/11/2025 à 10:13, Javier Jimenez Shaw via gdal-dev a écrit :
> Hi
> When I read some raster files (in particular thermal JPEG files), a
> side car file .aux.xml appears next to it.
> I would like to avoid the creation of this side car file, but I want
> to use any .aux.xml file if it is already there. Yes, I could imagine
> there is a performance impact if I read it several times, but I am
> going to read the file only once.
> The config option GDAL_PAM_ENABLED seems to be completely disabling
> PAM functionality:
> https://gdal.org/en/stable/user/configoptions.html#persistent-auxiliary-metadata-pam-options
> Reading the documentation, I would imagine that the PAM is completely
> disabled, not only the creation of the side car file while reading a
> raster.
> Is it posible to not create the .aux.xml, but use it if present?
> Thank you
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
