[gdal-dev] gdal mdim convert and grib2
Even Rouault
even.rouault at spatialys.com
Tue Nov 4 12:21:13 PST 2025
Scott,
is the band description (the one that is used in the classic data model,
and populated from the content of the .idx) somewhat predictable /
usable as an user input ? ("APCP:surface:53-59 hour acc fcst" in your
example). If so, gdal raster select could potentially be extended to
accept a --band-description switch to select a band from its description.
Even
Le 04/11/2025 à 20:35, Scott via gdal-dev a écrit :
> Using:
> GDAL 3.12.0 "Chicoutimi", released 2025/11/03
> The following returns almost immediately, if you know the band number.
> Unfortunately, with this data set, the bands and arrays aren't
> consistent across model runs, so I can't rely on a fixed band. A
> grib2.idx does exist on S3 (which is why using band works so fast):
> gdal raster select -i
> /vsis3/noaa-nbm-para-pds/blend.20251104/01/core/blend.t01z.core.f059.co.grib2
> -o blend.t01z.core.f059.co.tif --band 132 --co COMPRESS=DEFLATE
> --overwrite
> The following takes over 4 minutes to complete. Downloading the file
> locally only takes about 20 seconds.
> time gdal mdim convert -i
> -o blend.t01z.core.f059.co.tif --array "QPF06_0-SFC" --co
> COMPRESS=DEFLATE --overwrite
> If I download the file first, so it's local, then it completes
> immediately.
> Any thoughts on speeding this up? Ideally, I don't want to download
> the file first.
> Thanks!
> Scott
http://www.spatialys.com
