[gdal-dev] Unsure about significance of nodata:null in raster:bands
Even Rouault
even.rouault at spatialys.com
Tue Nov 4 17:07:27 PST 2025
> When using gdal raster info I have noted that in the "raster:bands"
> section (with output format set to default json) the nodata value of
> float rasters is always reported as "null". All attempts to change or
> set the nodata value seem unable to fix this. It only happens with
> float rasters - if you convert a float raster to int with
> gdal_translate, nodata is correctly reported. If you convert it back
> to float, it becomes null again. I've tried this on a few rasters and
> it seems consistent. All were GTiff format.
This is a bug specific to the STAC relate part of JSON output. Will be
fixed per https://github.com/OSGeo/gdal/pull/13333
> I was curious about this because I've been investigating an issue
> where raster2pgsql is seemingly refusing to recognize and not write
> empty tiles (as it should be without the -k flag). I was curious if
> this could be a bug or some other occurrence whereby it's not
> recognizing the nodata value of the raster properly, therefore leading
> to always writing the full raster.
> I know raster2pgsql specific questions aren't for here, I will make a
> similar mail to the postgis-users mailing list soon, I was just giving
> context.
Not sure about the raster2pgsql issue, but definitely not related to the
above bug.
Even
http://www.spatialys.com
