[gdal-dev] Georeference a pdf file
paul.malm at lfv.se
paul.malm at lfv.se
Thu Nov 6 00:29:59 PST 2025
I have a PDF file with a map, but without georeferenced parameters.
I know what coordinate reference system the PDF-map is drawn in.
Now I would like to georeferenced that PDF file, just add needed information. I have the coordinates for the 4 corners in WGS84.
I do not want to use gdalwarp as it warps the picture.
I only want to add the georeferenced to the PDF file, is that possible with GDAL?
Kind regards,
Paul
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251106/e7d93bbb/attachment-0001.htm>
