[gdal-dev] GDAL CLI converting to output datatype before performing calculation
Daniel Baston
dbaston at gmail.com
Thu Nov 13 07:02:43 PST 2025
It's a single-pixel raster. The first two values printed are the cell
center coordinates (0.5, 0.5), followed by the cell value (1).
Dan
On Thu, Nov 13, 2025 at 9:46 AM Rahkonen Jukka <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> I think I do not understand something simple, but how a byte type pixel
> can have one half as a value?
> 0.5 0.5 1
> -Jukka Rahkonen-
> ________________________________________
> Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> käyttäjän Daniel
> Baston via gdal-dev <gdal-dev at lists.osgeo.org> puolesta
> Lähetetty: Torstai 13. marraskuuta 2025 16.40
> Vastaanottaja: Henry Walshaw <henry at floodmapp.com>
> Kopio: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> Aihe: Re: [gdal-dev] GDAL CLI converting to output datatype before
> Hi Henry,The input values should not be rounded before doing the
> calculation. I get a correct result with both 3.12 and 3.11.5:$ gdal raster
> create --size 1,1 --burn 0.1 --output-data-type Float64 depth.tif$ gdal
> raster calc -i "A=depth.tif" -o footprint_b.tif --calc "A > 0 ? 1 : 0"
> --nodata none --ot Byte$ gdal raster convert footprint_b.tif
> --output-format XYZ /vsistdout/ERROR 6: Read or update mode not supported
> on /vsistdout0.5 0.5 1DanOn Thu, Nov 13, 2025 at 12:49 AM Henry Walshaw via
> gdal-dev <gdal-dev at lists.osgeo.org> wrote:Hi all,In the docs for gdal
> raster calc (
> https://gdal.org/en/stable/programs/gdal_raster_calc.html#cmdoption-calc)
> it statesInput rasters will be converted to 64-bit floating point numbers
> before performing calculations.However I’ve found that when using an
> integer output datatype the base data is rounded to an integer before
> performing the calculation. e.g. converting a flood depth input.tif raster
> to a simple water / no water footprint:
> gdal raster calc -i "A=depth.tif" -o footprint_b.tif --calc "A > 0 ? 1 :
> 0" --nodata none --ot Byte
> The expected result for a value of (say) 0.1 is 1, but in the above
> calculation it comes out as 0. Obviously I can leave the output datatype
> alone so it stays the same as the input’s 64-bit float, but it seems
> unnecessary. Am I looking at a bug, or is this expected
> behaviour?Regards,Henry_______________________________________________gdal-dev
> mailing listgdal-dev at lists.osgeo.orghttps://
> lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251113/211c5716/attachment-0001.htm>
