Greetings, When using gdal raster resize I can use --size 0,800 and it will compute the width. However, when using gdal vector rasterize --size 0,800 it throws the error: ERROR 1: Wrong value for -ts parameter. Having it compute the missing value is highly desirable! GDAL v3.12.0 Thanks! Scott -- www.postholer.com
