[gdal-dev] gdal rasterize vs resize
Even Rouault
even.rouault at spatialys.com
Sun Nov 16 11:40:18 PST 2025
Please file an issue about that
Le 16/11/2025 à 20:33, Scott via gdal-dev a écrit :
> Hey Jukka,
> Yes, the behavior has existed for quite some time on the utilities. If
> you know the extent it's easy to calculate the -tr, (max - min) / pixels.
> Being that the functionality exists elsewhere and given the fact that
> I'm LAZY, it would be nice to have everywhere. :)
> Thanks!
> Scott
> On 11/16/25 11:04, Rahkonen Jukka wrote:
>> Hi,
>> I believe it would not be extremely hard to compute the other size
>> parameter so that the result would have square pixels. As a
>> workaround, if you can guess an about suitable pixel size you can
>> define the resolution with equal x and y size:
>> gdal vector rasterize --resolution [pixelsize,pixelsize]
>> The behavior is not new. The traditional gdal_rasterize
>> https://gdal.org/en/stable/programs/gdal_rasterize.html requires also
>> both width and height.
>> -Jukka Rahkonen-
>> ________________________________________
>> Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> käyttäjän
>> Scott via gdal-dev <gdal-dev at lists.osgeo.org> puolesta
>> Lähetetty: Lauantai 15. marraskuuta 2025 21.45
>> Vastaanottaja: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
>> Aihe: [gdal-dev] gdal rasterize vs resize
>> Greetings,
>> When using gdal raster resize I can use --size 0,800 and it will compute
>> the width.
>> However, when using gdal vector rasterize --size 0,800 it throws the
>> error:
>> ERROR 1: Wrong value for -ts parameter.
>> Having it compute the missing value is highly desirable!
>> GDAL v3.12.0
>> Thanks!
>> Scott
>> http://www.postholer.com/
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
