[gdal-dev] What is the status of KML?
Simon Eves
seves at nvidia.com
Tue Nov 25 15:34:40 PST 2025
We have historically provided KML support in our GDAL-based import system using an old version of libkml which dates from the Google Code days. We had a cache of the .zip file so have not needed to download it afresh for a long time. I am belatedly testing using the v1.3.0 version available from https://github.com/libkml/libkml which was somebody's attempt to keep that library alive, but it is nearly as ancient (2015).
However, while naive replacement of our previous autogen-based libkml build (both shared and static) with the newer CMake-based one compiles just fine, GDAL (currently 3.10.3) is not at all happy with it as a static build, although a shared build seems OK.
Does anyone please have a known-working build incantation for libkml 1.3.0 plus current GDAL for an all-static build.
Alternatively, Even or whoever, is KML still a thing? How many people are likely to care if we deprecate support for it?
Simon Eves
Senior Rendering/Geospatial Software Engineer
NVIDIA (RAPIDS) (formerly Heavy.AI / Omnisci / MapD)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251125/a33d5cba/attachment-0001.htm>
