[gdal-dev] How to specify 'OUTPUT' when warping (reproject)
Nyall Dawson
nyall.dawson at gmail.com
Fri Oct 3 14:30:52 PDT 2025
On Sat, 4 Oct 2025, 2:00 am AF via gdal-dev, <gdal-dev at lists.osgeo.org>
wrote:
> Hello,
> A PyQGIS code needs to reproject one raster layer from a CRS to a new
> one. To begin with, I've tried to use only the minimal required options
> so the snippet reads:
> parameters = {
> 'INPUT': my_input_vector_layer,
Not sure if this is a typo (or a badly named variable, or ai slop code),
but it looks like you're trying to warp a vector later to a raster layer? 🤔
Nyall
'SOURCE_CRS': QgsCoordinateReferenceSystem(source_PROJ),
> 'TARGET_CRS': QgsCoordinateReferenceSystem(target_PROJ),
> 'RESAMPLING': 1,
> 'DATA_TYPE': 4,
> 'OUTPUT': '/home/ubuntu/my_new_raster.tif'
> terrain = processing.run('gdal:warpreproject', parameters)
> However, this doesn't do much as terrain is simply a dictionary with the
> keyword 'OUTPUT' and my_new_raster.tif is never created. Obviously I
> must be doing something wrong and suspect that might be related to
> 'OUTPUT'. The documentation at
> https://docs.qgis.org/testing/en/docs/user_manual/processing/toolbox.html#output-parameter-widget
> didn't dissipate my doubts so I'm unsure how to proceed.
> I also tried (an alternative method) calling gdal.Warp directly (not
> sure if this method is preferable to using processing.run) but it keeps
> saying that it only takes 2 arguments. I found a few examples online but
> they all have more than 2 arguments. For example
> options = gdal.WarpOptions(dstSRS=target_PROJ)
> warp = gdal.Warp('/home/ubuntu/pepe.tif',
> my_input_vector_layer, options)
> warp = None
> complains about including 3 and not 2 arguments. Same if I try including
> all arguments at warp.
> Thanks.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251004/fe18a1bc/attachment-0001.htm>
