[gdal-dev] gdal raster calc - a modulo operator (%)?
Laurențiu Nicola
lnicola at dend.ro
Tue Oct 7 09:34:25 PDT 2025
GDAL also supports https://github.com/ArashPartow/exprtk (which is available in the -full Docker image), which has a % operator, but I've never used it.
Laurentiu
On Tue, Oct 7, 2025, at 19:30, Scott via gdal-dev wrote:
> Greetings!
> I've been unable to find a modulo operator in CLI calc. It's not in the
> muparser functions or appear to be in the forth-coming 3.12 C pixel
> functions.
> This has been working with muparser, but it's messy every time you need
> a simple modulo. pixel is real or int, div is int:
> rint(pixel) - (rint(rint(pixel) / div) * div)
> Am I missing something? If not, consider this a feature request! :)
> Thanks!
> Scott
> www.postholer.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
