[gdal-dev] Issues with shapefiles with Z values?
Andrea Giudiceandrea andreaerdna at libero.it
Wed Oct 15 01:44:51 PDT 2025
Hi all,
I've also inspected the provided ESRI Shapefile layers and it seems to
me they are perfectly compliant to the Shapefile technical description
https://downloads.esri.com/support/whitepapers/mo_/shapefile.pdf for
PointZ PolyLineZ Shapefile types and are correctly displayed even using
ESRI ArcMap 9.3.1.
The ArcMap tool to validate the geometries and the ShapeChecker utility,
recommanded by ESRI, didn't find any error in such layers.
David, what online utility have you used? I've uploaded
driveway_points[.shp|.shx|.dbf] to
https://www.litchiutilities.com/shapefileToCsv.php and while it
generates 2 warning messages* it also nevertheless creates the requested
CSV file.
Regards.
Andrea
* Warning: unpack(): Type d: not enough input, need 8, have 0 in
/home/wesbarri/litchiutilities.com/php-shapefile-3.4.1/src/Shapefile/ShapefileReader.php
on line 317
Warning: current() expects parameter 1 to be array, boolean given in
on line 317
