[gdal-dev] [ogr2ogr] Anti-meridian issue when reprojecting from a Polar Stereographic projection to a geographic CRS
Even Rouault
even.rouault at spatialys.com
Sat Oct 18 15:11:03 PDT 2025
this issue will be fixed per https://github.com/OSGeo/gdal/pull/13243
Even
Le 14/10/2025 à 14:50, Andrey VI via gdal-dev a écrit :
> Hello.
> I can't reproject data from a Polar Stereographic projection
> (EPSG:3996)to a geographic projection (EPSG:4326) correctly using
> ogr2ogr. Command:
> ogr2ogr -t_srs EPSG:4326 -wrapdateline polys_4326.shp polys.shp
> ERROR 1: IllegalArgumentException: Points of LinearRing do not form a
> closed linestring ERROR 1: IllegalArgumentException: Points of
> LinearRing do not form a closed linestring ERROR 1:
> IllegalArgumentException: Points of LinearRing do not form a closed
> linestring ERROR 1: IllegalArgumentException: Points of LinearRing do
> not form a closed linestring ERROR 1: IllegalArgumentException: Points
> of LinearRing do not form a closed linestring ERROR 1:
> linestring
> As a result some polygons are broken and also some polygons appears
> with artifacts.
> The data used and the result (58 MB):
> https://drive.google.com/file/d/176jtROjjeTlAQTITAJ75tBT1GwiUzSUm/view?usp=sharing.
> How to reproject from a projection naturally crossing the
> anti-meridian to a geographic CRSwithout any errors using ogr2ogr?
> Andrey
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251019/1c36650c/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251019/1c36650c/attachment-0001.png>
