[gdal-dev] GDAL 3.12.0 "Chicoutimi" beta1 is available for testing
Even Rouault even.rouault at spatialys.com
Mon Oct 20 12:06:35 PDT 2025
I've prepared a beta1 of GDAL 3.12.0 "Chicoutimi" to get feedback from
early testers,
for the following next 2 weeks before the release candidate.
The NEWS file is here:
   https://github.com/OSGeo/gdal/blob/v3.12.0beta1/NEWS.md
and the gist at the end of this email ([1])
Please file tickets at https://github.com/OSGeo/gdal/issues for issues
you'd find
(or pull requests to fix them)
Note that the release process has been largely automated with a Github
Action,
thanks to the work of Ogi Moore during the Riga community sprint. Huge
thanks to him!
This both reduces manual work for the release manager and also increases the
security of the release process.
I have *not* branched off yet master for release/3.13, so be careful with
material that goes into master until that's done.
Source snapshots at:
- https://download.osgeo.org/gdal/3.12.0/gdal-3.12.0beta1.tar.gz
- https://download.osgeo.org/gdal/3.12.0/gdal-3.12.0beta1.tar.gz.md5
- https://download.osgeo.org/gdal/3.12.0/gdal-3.12.0beta1.tar.gz.sig
- https://download.osgeo.org/gdal/3.12.0/gdal-3.12.0beta1.tar.xz
- https://download.osgeo.org/gdal/3.12.0/gdal-3.12.0beta1.tar.xz.md5
- https://download.osgeo.org/gdal/3.12.0/gdal-3.12.0beta1.tar.xz.sig
- https://download.osgeo.org/gdal/3.12.0/gdal3120beta1.zip
- https://download.osgeo.org/gdal/3.12.0/gdal3120beta1.zip.md5
- https://download.osgeo.org/gdal/3.12.0/gdal3120beta1.zip.sig
Autotest snapshots:
- https://download.osgeo.org/gdal/3.12.0/gdalautotest-3.12.0beta1.zip
The GPG signing key used by the github action is a new one. You'll find
in [2] the corresponding public key.
Docker images are available (also automatically produced by the Github
Action):
- ghcr.io/osgeo/gdal:alpine-small-3.12.0beta1
- ghcr.io/osgeo/gdal:alpine-normal-3.12.0beta1
- ghcr.io/osgeo/gdal:ubuntu-small-3.12.0beta1
- ghcr.io/osgeo/gdal:ubuntu-full-3.12.0beta1
(note that -latest images of master are also now automatically refreshed
on a daily basis by a nightly job)
Even
[1] In a nutshell...
* New 'gdal' command line interface capabilities:
   - Add 'gdal raster as-features' (#12970)
   - Add 'gdal raster blend' (port of hsv_merge.py + regular alpha blending)
   - Add 'gdal raster compare' (port of gdalcompare.py) (#12757)
   - Add 'gdal raster neighbors' (#12768)
   - Add 'gdal raster nodata-to-alpha' (#12524)
   - Add 'gdal raster pansharpen' (port of gdal_pansharpen.py)
   - Add 'gdal raster proximity' (#12350)
   - Add 'gdal raster rgb-to-palette' (port of rgb2pct.py)
   - Add 'gdal raster update'
   - Add 'gdal raster zonal-stats'
   - Add 'gdal vector check-coverage'
   - Add 'gdal vector check-geometry'
   - Add 'gdal vector clean-coverage'
   - Add 'gdal vector index' (port of ogrtindex)
   - Add 'gdal vector layer-algebra' (port of ogr_layer_algebra.py)
   - Add 'gdal vector make-point'
   - Add 'gdal vector partition'
   - gdal vector pipeline: add limit step
   - Add 'gdal vector set-field-type'
   - Add 'gdal vector simplify-coverage'
   - Add 'gdal mdim mosaic' (#13208)
   - Add 'gdal dataset' port of 'gdal manage'
   - Make 'gdal pipeline' support mixed raster/vector pipelines
   - Pipeline: add support for nested pipeline (#12874)
   - Pipeline: add support for a 'tee' step (#12874)
   - Move 'gdal vector geom XXXX' utilities directly under 'gdal vector'
   - Rename 'gdal vector geom set-type' as 'gdal vector set-geom-type'
   - gdal raster reproject: add a -j/--num-threads option and default to
ALL_CPUS
   - Make 'gdal raster fill-nodata/proximity/sieve/viewshed' pipeline-able
   - gdal raster mosaic/stack: allow it to be the first step of a raster
pipeline
   - gdal pipeline: allow to run an existing pipeline and override/add
parameters
   - Improved Bash completion
   - Many other improvements to existing utilities (see below)
* VRT pixel functions: Add mean, median, geometric_mean, harmonic_mean, mode
    (#12418), and handle NoData values
* Add C/C++/Python API for [raster band
algebra](https://gdal.org/en/latest/user/band_algebra.html):
   arithmetic operators, comparison operators, AsType(),
   gdal::abs()/sqrt()/log10()/log()/min()/max()/mean()/IfThenElse()
functions
* Add MiraMon raster driver: read-only support (#12293)
* ADBC driver: support for ADBC BigQuery driver (requires BigQuery ADBC
driver)
* JSONFG driver: add read/write support for curve and measured geometries;
   update to 0.3.0 spec
* Parquet: add update support using OGREditableLayer mechanism
* Add C++ public header files for raster functionality
* Security: avoid potential path traversal in several drivers
* Various code linting, static code analyzer fixes, etc.
* Significant automation of the release process
* Add Docker attestation (#13066)
* Bump of shared lib major version
[2] $ gpg --armor --export 7B130E955B44D87CCE2765F0DBD81FF52EC2A42A
-----BEGIN PGP PUBLIC KEY BLOCK-----
mQINBGjlDXoBEACjbYUouwHnW+X/xK51AfwN1vTrJn+pZziGGLobD4Jfs4gU4PwQ
dEw1bFj6tsgBrJ7hrKmcyd0bBQiKU1FTYy+tOu768t9qlC7HC3JfRBACrGn3Svz4
evinQkq5GGcZ1FkJhRKgEIxJLGppG7O45XEFYdcbCkLqC8uyu2+PbY2SYXlzlKs8
DLiAwqX670eZ78pDtynJj81CRowSqyNBOzaltR6OLCsYZrYzAYYtBqSiifKoIpm/
sV4VRvUuWaaUNNMPPRLt+mV+iIYm8cKLH2uyozZWIfOSck7I30fGIuuUhulc41bi
3WNV+QtOepPyuMolab8JNbaRJXAFxQ5Q2k5ZyzXvpuAEqwrhaFIroc7LvkQ4RLlT
r6BkFUzvCCjRWG5jCFA0CjvvvYG9DPSUKdSaD2Vxfor/cwSRqnPYwRauFMuST57H
exrLYJZqfeZuqV2mlI8wVvh3tO9oC/pGmggV3B1KxYvzj2I/nQ/bnugveEvD005j
EcfSlmAPWcuily+rgB9xqed0tZwG0A9fjY/gveqxLVE41EIoAfkdeRl+KVOqEEYk
cyiJQdFKBuGxemEP2cfDnROUawp+1XXEuA1MGkLvB+6nNIp1e+mhUtWfDY70MEz1
l7J49MUZBfPM3vy63t7ihlPLIP9IUcO9j9rfy1iW8t86qG3CnZE/rsnVZwARAQAB
tCRHREFMIFJlbGVhc2UgQm90IDxnZGFsb3JnQGdtYWlsLmNvbT6JAlQEEwEKAD4W
IQR7Ew6VW0TYfM4nZfDb2B/1LsKkKgUCaOUNegIbAwUJA8JnAAULCQgHAgYVCgkI
CwIEFgIDAQIeAQIXgAAKCRDb2B/1LsKkKpY+D/9hVR9JIQNT3So4fg/fQx36azSf
kVzO4nS0lZhSxR4/Xig5Zqq8EOFk7ipWwb4hhivPi7yR49BhVSQbHo36+jNbC5k/
jDMsZ+9CNzUjp1XSH/v06mcdSD4LB4vSvHBfLjDdV7OoOGnExkEyqBcoje53tW6p
tKQGwqZ3ilZs75GkLO1UC3DNQ9VpVc7lk1Cv+npto86A6CWMAC7q+n540wC/oTj7
APn6dz1S0LAPWR9v0aBoLMoRP9YiRQSmQmyQsKe3HJd4c7hSdWyST/PIMvPZawpP
BYG+JRRuRoWm6zjJIWnvqj9IZeFkQv1fKqYHKW86aITTqGGF6kcq83mf2XH26KQR
mu8ArI5aLULmpKA67p2RXxyPdoSNiaiP8UuWQ18rnEA/Hedz2sgBYSvjeYYziTRm
wgiRbts4MjB5pj+JGKtX7FEL6HuPDVnMYGc8n8bO8qiKctuYMwBM/KRE+2e3zx0m
m5YXjjCSvBiTLYNhvrrQ5pxiUK5xiAH0G/MzPXjJToJzLrHn0vqRVHXs9F8d9zLe
o6E4S8VVgyJ9zdXkYtj9nyL9jb00K+jj/g4avpnOKTuIgpsTR2ntxWz2liWU6Saz
03Vrd9mVwgU7NBnYAMXOg54eYwhyWkGvbFHvCK6ijL1+SaAkN9mVs5VTJMpGiJ9s
qj7DbIY0GwZQMVSvxQ==
=FY/p
-----END PGP PUBLIC KEY BLOCK-----
http://www.spatialys.com
