[gdal-dev] GDAL 3.12.0 "Chicoutimi" beta1 is available for testing
Even Rouault
even.rouault at spatialys.com
Tue Oct 21 10:59:37 PDT 2025
> - I expected the wheel name to have beta1. But I ended up with:
> /usr/pkg/lib/python3.13/site-packages/gdal-3.12.0.dist-info/METADATA
> /usr/pkg/lib/python3.13/site-packages/gdal-3.12.0.dist-info/RECORD
> /usr/pkg/lib/python3.13/site-packages/gdal-3.12.0.dist-info/WHEEL
> /usr/pkg/lib/python3.13/site-packages/gdal-3.12.0.dist-info/entry_points.txt
> /usr/pkg/lib/python3.13/site-packages/gdal-3.12.0.dist-info/top_level.txt
> This was easy to deal with for testing, and it's possible it's an
> issue on my end. I am curious if others see this.
I've not explored how betas suffixes should work with Python. Anyway
they are not meant to be used "for real".
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251021/b8db6e43/attachment.htm>
