[gdal-dev] Ignoring KML/KMZ id field
Peter Townsend
peter.townsend at maplarge.com
Tue Oct 21 15:07:39 PDT 2025
I'm testing upgrading from GDAL 3.9 to 3.11, but I had some old unit tests
fail that check KMZ to CSV conversion output. In particular, a new and
empty "id" column has appeared in the CSV.
I'm guessing it's related to this LIBKML_ID_FIELD change in 3.10.
https://gdal.org/en/stable/drivers/vector/libkml.html#fields
Is there a config or command line option that can tell it to ignore the id
field? Either by just not including it from the KMZ or alternately
something like an ignore list for CSV headers?
Peter Townsend
Senior Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251021/01801a50/attachment-0001.htm>
