[gdal-dev] [gdal 3.12beta1] Default projection for SHAPE files?
Momtchil Momtchev momtchil at momtchev.com
Wed Oct 22 07:42:03 PDT 2025
Before GDAL 3.12 this file
https://github.com/mmomtchev/node-gdal-async/blob/main/test/data/shp/sample.shp
did not have a projection. With 3.12, it returns a valid projection.
The projection is obtained with GetProjectionRef() and then
importFromWkt() to construct the object.
I don't see anything in the changelog that explains it, is this expected?
Momtchil Momtchev <momtchil at momtchev.com>
