[gdal-dev] Failing to build with libparquet
Ari Jolma
ari.jolma at gmail.com
Wed Oct 22 07:48:37 PDT 2025
Doh, I thought 3.9 was the latest as it was the last in git branch -a.
Ok, thanks Even.
Ari
Even Rouault kirjoitti 22.10.2025 klo 17.36:
> Hi Ari,
> This should be fine with master or latest state of the release/3.11
> branch, or try to use maybe Arrow 18 or something if you need to sick
> with release/3.9. There are from time to time breakages in the Arrow
> C++ API, and older GDAL releases won't build for that reason with
> newer Arrow releases.
> Even
> Le 22/10/2025 à 16:06, Ari Jolma via gdal-dev a écrit :
>> I'm trying to build release/3.9 with libparquet from
>> https://packages.apache.org/artifactory/arrow/ubuntu/
>> libparquet2100/jammy,now 21.0.0-1 amd64
>> The error is
>> /home/ari/github/gdal/ogr/ogrsf_frmts/parquet/ogrparquetdriver.cpp:
>> In function ‘GDALDataset* OGRParquetDriverOpen(GDALOpenInfo*)’:
>> /home/ari/github/gdal/ogr/ogrsf_frmts/parquet/ogrparquetdriver.cpp:700:43:
>> error: too many arguments to function
>> ‘arrow::Result<std::unique_ptr<parquet::arrow::FileReader> >
>> parquet::arrow::OpenFile(std::shared_ptr<arrow::io::RandomAccessFile>,
>> arrow::MemoryPool*)’
>> 700 | auto st = parquet::arrow::OpenFile(std::move(infile),
>> 701 | poMemoryPool.get(), &arrow_reader);
>> In file included from
>> /home/ari/github/gdal/ogr/ogrsf_frmts/parquet/ogr_include_parquet.h:58,
>> from
>> /home/ari/github/gdal/ogr/ogrsf_frmts/parquet/ogr_parquet.h:38,
>> from
>> /home/ari/github/gdal/ogr/ogrsf_frmts/parquet/ogrparquetdriver.cpp:35:
>> /usr/include/parquet/arrow/reader.h:368:46: note: declared here
>> 368 | ::arrow::Result<std::unique_ptr<FileReader>> OpenFile(
>> gmake[2]: ***
>> [ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/build.make:76:
>> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/ogrparquetdriver.cpp.o]
>> Virhe 1
>> gmake[1]: *** [CMakeFiles/Makefile2:9944:
>> ogr/ogrsf_frmts/parquet/CMakeFiles/ogr_Parquet.dir/all] Virhe 2
>> gmake: *** [Makefile:146: all] Virhe 2
>> what might be the issue?
>> Ari
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
