[gdal-dev] [gdal 3.12beta1] Default projection for SHAPE files?
Even Rouault even.rouault at spatialys.com
Wed Oct 22 08:13:37 PDT 2025
This is the line yo were looking for ;-)
* GDALDataset::GetSpatialRef(): make it work on vector datasets (#12956)
Even
Le 22/10/2025 à 16:42, Momtchil Momtchev via gdal-dev a écrit :
> Before GDAL 3.12 this file
> https://github.com/mmomtchev/node-gdal-async/blob/main/test/data/shp/sample.shp
> did not have a projection. With 3.12, it returns a valid projection.
> The projection is obtained with GetProjectionRef() and then
> importFromWkt() to construct the object.
> I don't see anything in the changelog that explains it, is this expected?
http://www.spatialys.com
