[gdal-dev] About VRT file size
Even Rouault
even.rouault at spatialys.com
Wed Oct 22 17:02:20 PDT 2025
Le 23/10/2025 à 01:37, zrh via gdal-dev a écrit :
> Hi, everyone,
> I want to know the max size of a VRT file.
No fixed limit, but how much usable RAM your process has access to. My
guess-timate would be that you need about between 2 and 10 times the VRT
file size.
> When I use gdal_translate to convert a vrt to tiff, I got error:
> CPLMutexHolder: Failed to acquire mutex!
> ERROR 2: Cannot allocate CPLXMLNode
> It seems that memory allocation issue.
> I use gdal_translate.exe with x86 version, not x64.
You pretty much diagnosed the cause of the issue...
If you use VRT in a mosaicing context, you'd rather want to use
https://gdal.org/en/stable/drivers/raster/gti.html instead of VRT with a
very large number of sources. The RAM requirements of GTI are very small
compared to VRT.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251023/49c9c35c/attachment.htm>
