[gdal-dev] [gdal 3.12beta] Normal chain of explicit destruction does not work with ComputedDataset
Momtchil Momtchev
momtchil at momtchev.com
Fri Oct 24 04:33:08 PDT 2025
Is there any way to know whether this is a GDALComputedDataset if
everything I have is a GDALDataset pointer?
On 24/10/2025 12:55, Even Rouault wrote:
> Hi,
> you should not destroy the dataset of a GDALComputedRasterBand. The
> GDALComputedRasterBand destructor does that automatically.
> Even
> Le 24/10/2025 à 12:40, Momtchil Momtchev via gdal-dev a écrit :
>> I have modified one of the algebra examples as follows:
>> #include<gdal_priv.h>
>> intmain() {
>> GDALAllRegister();
>> autopoDS=std::unique_ptr<GDALDataset>(GDALDataset::Open("test/data/a39se10.jpg"));
>> auto&R=*(poDS->GetRasterBand(1));
>> auto&G=*(poDS->GetRasterBand(2));
>> auto&B=*(poDS->GetRasterBand(3));
>> GDALRasterBand*graylevel=newGDALComputedRasterBand((0.299*R+0.587*G+0.114*B).AsType(GDT_Byte));
>> autopoGTiffDrv=GetGDALDriverManager()->GetDriverByName("GTiff");
>> poGTiffDrv->CreateCopy("graylevel.tif", graylevel->GetDataset(),
>> false, nullptr, nullptr, nullptr))
>> .reset();
>> GDALDataset*dh=graylevel->GetDataset();
>> deletegraylevel;
>> dh->Close();
>> return0;
>> I allocate graylevel on the heap, I obtain a pointer to the
>> GDALComputedDataset and I attempt to destroy first the
>> GDALComputedRasterBand then the GDALComputedDataset. This fails with
>> a crash in Close. Is this a bug or am I not supposed to do this? I am
>> doing it, because this is the usual chain of destruction events for
>> objects returned to JS. RasterBands hold a reference to their Dataset
>> in order to prevent the object from being GCed.
>> Momtchil Momtchev<momtchil at momtchev.com>
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251024/f10b4990/attachment.htm>
