[gdal-dev] Ignoring KML/KMZ id field
Peter Townsend
peter.townsend at maplarge.com
Fri Oct 24 10:28:24 PDT 2025
"SELECT * EXCLUDE (id) FROM layer_name"
That worked, thanks!
On Wed, Oct 22, 2025 at 4:30 AM Even Rouault via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> If you're in code, you can skip fields using SetIgnoredFields():
> https://gdal.org/en/stable/doxygen/classOGRLayer.html#aaf3f2e7ee476337082cea814226be11a
> SetIgnoredFields() doesn't change the schema. It just tells the driver
> that it doesn't need to fill the fields.
> For a tool like ogr2ogr, you could try -unsetFid, or build a -fieldmap if
> it isn't too messy.
> -unsetFid will not work here because that's a regular field
> The following should do: -sql "SELECT * EXCLUDE (id) FROM layer_name"
> -- http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Peter Townsend
Senior Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20251024/a90da246/attachment-0001.htm>
