[gdal-dev] Slightly-off failing tests on i686
yosh
yosh-git at riseup.net
Wed Oct 29 05:37:14 PDT 2025
Heya,
I'm currently in the process of updating libgdal for void linux. In the
process, I actually added the test suite to the package, and it seems to be
failing on i686/32bit:
https://github.com/void-linux/void-packages/actions/runs/18897850572/job/53938975118?pr=57703#step:7:7606
in case github actions culls this sooner than expected:
https://0x0.st/K_pP.txt
It seems to be ever so slightly off the expected results for numerical
stuff. is this known/expected behavior and/or a supported configuration? Mainly
wondering if it'd be better to skip the tests for i686 or not.
Best,
yosh
