[gdal-dev] Slightly-off failing tests on i686
Even Rouault even.rouault at spatialys.com
Wed Oct 29 06:01:54 PDT 2025
we do have a CI configuration for i386 using clang in debug mode. Maybe
your use of gcc in -O2 yields to slightly different results in some cases.
BTW, I see in your log a crash on test_tiff_write_66 that could be
avoided by setting the SKIP_MEM_INTENSIVE_TEST environment variable
before running the test suite (which our CI does)
Even
Le 29/10/2025 à 13:37, yosh via gdal-dev a écrit :
> Heya,
> I'm currently in the process of updating libgdal for void linux. In the
> process, I actually added the test suite to the package, and it seems to be
> failing on i686/32bit:
> https://github.com/void-linux/void-packages/actions/runs/18897850572/job/53938975118?pr=57703#step:7:7606
> in case github actions culls this sooner than expected:
> https://0x0.st/K_pP.txt
> It seems to be ever so slightly off the expected results for numerical
> stuff. is this known/expected behavior and/or a supported configuration? Mainly
> wondering if it'd be better to skip the tests for i686 or not.
> Best,
> yosh
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
