[gdal-dev] podofo 1.0.2 ships with Fedora 43, breaks source builds
Roger Bivand Roger.Bivand at nhh.no
Fri Oct 31 05:37:06 PDT 2025
For GDAL 3.11.4, 3.11.5RC1 and 3.12.0beta1, source builds fail at the same point:
[ 45%] Building CXX object frmts/pdf/CMakeFiles/gdal_PDF.dir/pdfdataset.cpp.o
/home/rsb/topics/gdal/gdal-3.11.4/frmts/pdf/pdfdataset.cpp: In static member function ‘static PDFDataset* PDFDataset::Open(GDALOpenInfo*)’:
/home/rsb/topics/gdal/gdal-3.11.4/frmts/pdf/pdfdataset.cpp:5160:36: error: ‘class PoDoFo::PdfPage’ has no member named ‘GetRotationRaw’; did you mean ‘GetRotation’?
 5160 |         dfRotation = poPagePodofo->GetRotationRaw();
      |                                    GetRotation
With Fedora 42, the podofo version was 0.10.5, which built and passed autotests.
There may be other package version increment issues on Fedora 43, but this is consistent.
Roger
Roger Bivand
Emeritus Professor
Norwegian School of Economics
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway
