[gdal-dev] podofo 1.0.2 ships with Fedora 43, breaks source builds
Even Rouault
even.rouault at spatialys.com
Fri Oct 31 06:18:41 PDT 2025
Hi Roger,
thanks for the report. This will be fixed per
https://github.com/OSGeo/gdal/pull/13308 . Too late for 3.11.5 but will
make it into 3.12.0RC1 planned for next week
Even
Le 31/10/2025 à 13:37, Roger Bivand via gdal-dev a écrit :
> For GDAL 3.11.4, 3.11.5RC1 and 3.12.0beta1, source builds fail at the same point:
> [ 45%] Building CXX object frmts/pdf/CMakeFiles/gdal_PDF.dir/pdfdataset.cpp.o
> /home/rsb/topics/gdal/gdal-3.11.4/frmts/pdf/pdfdataset.cpp: In static member function ‘static PDFDataset* PDFDataset::Open(GDALOpenInfo*)’:
> /home/rsb/topics/gdal/gdal-3.11.4/frmts/pdf/pdfdataset.cpp:5160:36: error: ‘class PoDoFo::PdfPage’ has no member named ‘GetRotationRaw’; did you mean ‘GetRotation’?
> 5160 | dfRotation = poPagePodofo->GetRotationRaw();
> | GetRotation
> With Fedora 42, the podofo version was 0.10.5, which built and passed autotests.
> There may be other package version increment issues on Fedora 43, but this is consistent.
> Roger
> Roger Bivand
> Emeritus Professor
> Norwegian School of Economics
> Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway
> Roger.Bivand at nhh.no
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
