[gdal-dev] Corner Coordinates for GeoTIFF/GeoPDF
    Cory Foy
    foyc at flighttactics.com
    Thu Sep  4 11:49:32 PDT 2025
> I apologize. I'm not familiar with the GetExtent() function. So this is just a guess and feel free to ignore it. Given that GetExtent() reports 2 coordinates, it seems to describe an axis aligned bounding. GeoTransform() provides information to describe an oriented bounding box. Could this perhaps be the source of disagreement between the two routines?
Thanks David. I realize now what’s going on is GetExtent and GetGeoTransform are returning different values than the command line gdalinfo is.
For example, running gdalinfo on my PDF shows:
GeoTransform =
  -8800981.741226587, 1.534954250051887, 0.7153177546590841
  4288851.899958452, 0.7158702972076904, -1.534439284842128
Corner Coordinates:
Upper Left  (-8800981.741, 4288851.900) ( 79d 3'38.03"W, 35d54'51.91"N)
Lower Left  (-8800543.967, 4287912.823) ( 79d 3'23.87"W, 35d54'27.31"N)
Upper Right (-8799766.057, 4289418.869) ( 79d 2'58.72"W, 35d55' 6.76"N)
Lower Right (-8799328.283, 4288479.792) ( 79d 2'44.56"W, 35d54'42.16"N)
Center      (-8800155.012, 4288665.846) ( 79d 3'11.30"W, 35d54'47.03”N)
But calling it from my compiled version in the app on the same file gives me:
GeoTransform =
-8800981.488120455, 1.5351602235290571, 0.7144694099544626,
4288852.103036083, 0.7156171000026056, -1.5347947295515767
And an extent of [-8800981.488120455, -8799328.385944527, 4287912.808661598, 4289418.871779285]
All of which is _close_ but obviously not the same. Gdalinfo is the correct representation, so I’m not sure why I’m getting the data I’m getting from my compiled version. They’re both from 3.11. But that explains why I was so confused.
Thanks for at least giving it a look and guess - going to have to figure out why these are getting different values.
Cory
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20250904/e459f49d/attachment.bin>
