[gdal-dev] GDAL Maintainers Meeting Minutes
    Howard Butler
    howard at hobu.co
    Fri Sep  5 08:30:28 PDT 2025
Howard Butler, Dan Baston, Alessandro Pasotti, Michael Sumner, Even Rouault, Mike Smith, Norman Barker, Chris Toney, Daniel Morissette and Javier Jimenez Shaw held the monthly GDAL Maintainers Meeting on 08/28/2025. The following items were discussed and reported upon:
Project News
* Maxar is renewing its Bronze GDAL sponsorship for 2025. Thanks Maxar!
* Google is renewing its Silver GDAL sponsorship for 2025. Thanks Google!
* Many GDAL team members including Even, Dan, Mike Smith, Seth, Jukka, and Javier will be at the OSGeo Community Sprint in Riga Sept 29-Oct 3. See https://www.osgeo.org/events/join-osgeo-community-sprint-2025-at-bids-25-riga-latvia/ for more details.
Maintenance activities update
Alessandro
* PR reviews
* 'gdal raster contour' half-pixel issue https://github.com/OSGeo/gdal/issues/12938
Dan
* Add "gdal vector check-geometry" and "gdal vector check-coverages" command-line utilities to check that vector features have valid/simple geometries and form a valid polygonal coverage (#12880, #12908)
* Add "gdal vector clean-coverage" command-line utility to remove gaps and overlaps from a polygon dataset (#12819)
* Add "gdal raster as-features" command-line utility to convert raster pixels into tabular features (#12970)
* Fix bounding box check in "gdal raster clip" (#12814)
* Fix invalid memory access when reading values from a raster attribute table (#12862)
* Add Python API documentation for raster attribute tables (#12863), Algorithms (#12987), and Dataset GetExtent methods (#12860)
* Improve organization of Python API documentation (#12971)
* Fix typos in documentation for pipeline substitutions (#12969)
Even
* 70+ PRs and tickets
* CLI enhancements – skip-errors
* Allow 'gdal raster info', 'gdal vector info', and 'gdal raster tile' to be last stages of pipeline
* 'gdal vector info --limit' to control output volume
* GDALG pipeline CLI substitutions – reuse the same pipeline for inputs and parameters that are substitutable during the CLI call
* Security pass to prevent relative filename traversal and injections in all drivers except VRT. There are no known exploits or reports about this, but it seems prudent to prevent.
* VSI code linting and unique_ptr usage
* 30%+ PNG tile speedup in compression scenarios
* Planning to attend the OSGeo Community Sprint in Riga
Javier
Mike Smith
Chris Toney
* gdalraster R bindings work – added new CLI bindings to R
The next GDAL Maintainers Meeting is 09/25/2025 at 13:00 UTC. GDAL PSC members and Pull Request contributors are welcome to contact me for an invite.
Howard
